Please help define fault code B2D40 on a 2020 RT Limited.
ThreeWheels
I have a 2020 RT Limited. I took a small hit while in reverse. Not a lot of damage to the Spyder but I now have an active fault code B2D40. What does this mean and how can I clear it?
There is a sensor that connects from the rear swing arm to the frame - I forget the name. Maybe that got jumbled? It throws an error if you forget to reconnect it after taking off & replacing the rear tire. Maybe?!
I cannot find that code in the service manual or in the extended list of codes that are not included in the manual. Normally a fault code that starts with "B" is a body code. Anyone with BUDS2 can find out what it means...
