:hun: Sure you can use Pingel Chocks or any other sort of chocks for your Spyder... it may be me, but I don't quite get the what or why of what you are asking?!? :dontknow:
Any 'fixed or removable' chock (made by Pingel or anyone else) will work to stop your Spyder moving if fitted/used properly..... AFAIK Pingel chocks are just one make of 'drive in' chocks, all of which can be used just so long as the wheel will fit inside the open end of the chock.
Standard Spyder front tires are a nominal 165mm wide, ie 165/55R15 or similar in14" dia tires for those Spyders still running 14" front wheels instead of the newer post 2013 15" rims. Some of us run slightly wider tires on the std rims (I run 175/60R15's) & some few run even wider rims so they can fit tires that are wider, some almost as wide as the rears.... :shocked:
If you want a 'drive-in chock' (made by Pingel or anyone else) to suit your Spyder, you just need to purchase a chock that is wide enough to allow your rims & tires to go in, & you might need to specify one low enough to avoid hitting the 'A' arms or fenders on the sides of the chocks too. :thumbup:
Does that cover what you were after?? :dontknow:
