Roger
Ok so i removed those 2 red reflectors on each side of the back wheel and added some leds that i bought from autozone very easy to do first i pulled as much of the reflecter off. once i got started i stuck a small flat screwdriver behind it and slowly pryed it off and you can get it all off this way. Then i used a razor blade to get the rubber and glue off wiped it down with alcohol then applied the light it has 3m tape on it so you know its good. I measured my wires to the length i needed to tap in the wires for the license plate light. what i did was remove the back fender ran my wire between the fender and the fender frame then spliced into the wires made my connection and put it back to gether. In the next photo is the picture of that big box for the license plate light which i will be replaceing with one from extreme kempy will post picture when i install it. and the last picture installed some more leds on the inside of my floorboards i already have them on the outside edge. This is a very easy mod and fun to do.
