PHONE volume LOUD, but not GPS or HEADSET - am I missing something?
JKMSPYDER
I have an Apple XR iPhone, a Garmin 595 GPS, and a SENA 20S Evo headset. I can hear the phone music and the GPS directions thru my headset at a comfortable level. I have the volume turned all the way up on my phone and control the volume thru my headset. The problem happens if I get a phone call and answer thru my headset. The volume is overpowering and I have to turn it down via the headset. I have tried controlling the volume thru my GPS but it doesn't solve the problem. It seems to me the volume from a phone call would be the same as the volume from music from the phone and the GPS. Am I missing something??
Check the volume on the phone. A lot of newer phones have different volume levels for calls vs media. Easy test is to connect the phone to the Sena. Place a call and turn down the volume of the phone. Then, play some media from the phone and you should be able to see the difference. There should also be a setting in the phone's volume control option to just look and verify the volume level of calls vs media.
Good luck
Also be aware that you may be only able to adjust phone volume while the phone call is active. The same for gps and music. The gps has to be speaking directions in order to adjust the gps volume. Same with music.
PHONE-volume-LOUD-but-not-GPS or headset
Doesn't sena have an app to make adjustments to the volumes of various inputs and microphone adjustments???
Al in Kazoo
I fought with this issue on my Cardo unit. As others have said, to adjust the volume you have to be in an active mode for the function you want to adjust, i.e. phone call, music etc. Addressing your specific issue, your phone may be recognizing your unit as an earbud, so you would have to adjust the volume while using an earbud (or com set). It should then remember the volume for that function after that.
