tommyoneleg
What part numbers were the filters?
Crank Case air filter 62-1250
Idle air hose filter 62-1160
For the air intake I used RU-2920 - This is the one I had to do a little extra since the Dual Flanges are 16mm apart and I needed them about 6mm apart so I put a little metal strips held on by metal straps around them and I got just enough of an angle so they all hooked up, if you can see it in the pictures. And it just fit with about 4mm or 1/8 inch to spare on the height. I also cut my air box apart to have something to hook the flanges to.
I should have ordered the RD-4600 and had K&N reduce the height of it from 6.5 inches to 3 inches but the cost was to much for me. That is the one reason I did not order a kit already made and I have been doing stuff since 1985 when I first started racing bike back then.
Also I have a 2009 RS, if you need more pictures I have some more.
