people in front pull over?
SAPD911
I have had 5 different people pull over when I get behind them? Do they think I am the po-po??? I don't get it.
I have had the same experience with my 2012 RT. I followed my brother (who was driving his car). He said it looked like I was flashing my headlights at him all the time and it was distracting. I was told that my headlights are not adjusted properly and that my rear suspension is not set stiff enough.
The headlight shutter when on low beam bounces. Causing some to think you are flashing your lights. Others may tell you you have a light that's flickering.
it's the nature of the beast.. at least they are pulling over so you can pass them easier.. and why are they feeling guilty anyway?:rolleyes:
Due to the prism effect it looks like you're flashing blue lights too. During the day, leave them on high beam, that lessens the "flash". At night, they just have to deal with it.
Ride with your high beams on during the day. It makes you so much more visible and your won't piss off the people in front of you.
The Spyder RS and RT have projection headlight lenses, that cast a narrow beam. In the daytime the focused portion of the beam will tend to bounce in and out of view of oncoming drivers or drivers looking in their mirrors. To them it looks like you are flashing your lights at them. All motorcycles, being lightweight vehicles, tend to do this when they bounce, but the narrow beam cast by the projector lenses makes the effect much stronger. Having the headlights adjusted too high, having the rear suspension set too soft, or even carrying a passenger can raise the beam and make things worse. Adjust your headlights a little lower and/or increase your rear suspension setting/preload and ride with your high beams on during the day to lessen this problem. If it makes you feel any better, I also ride an ex-CHP BMW (in Michigan) and they pull over when they see that coming, too.
I felt the same way and I have an 09 gs :bowdown:
I think its the roar from the engine that make em move aside :ohyea:
My wife complains my high beams are to bright when I'm following her on the Spyder, but doesn't have a problem with them on low, so its either my headlights are adjusted just right or..... Could it be my superior driving abilities?
Better they are too bright then they can't see you coming. Get your wife her own Spyder then you won't have that problem :roflblack:
If you have a black Spyder and wear a white helmet it is almost comical. They KNOW you are the cops--transplanted from the TV show Almost Human!
Don't know..!!
about others but on a trip down the coast I had a friend on an RT ryding behind me. At certain times the flashing lights were changing colors reds and blues. This may be a combination of polorized sunglasses and glare but it did look like police lights...:yikes:
The polarized lenses could make it worse, but there is a prismatic effect a the edges of focus of the projector lenses, so at some angles the lights aren't bright, they are colored...and flashing.
They have you covered. I see a lot of LEO's and have wondered about getting stopped many times. Never happened though.
