Pedal Commander and Error P2135
rsnider1961
Love the Pedal Commander and don't want to ride without it, however, on a ride this weekend I had an error code of P2135 come up 2 time during my 600 mile trip up to Georgia. First time this occurred, I googled the code, removed the pedal commander and finished the day. At the hotel that night, I reinstalled pedal commander and was able to ride the next day for an additional 200 miles to location before the error code came back on. This time I let the bike sit for a couple hours while I got lunch, went back and cranked the Spyder - the error came back on, I cut the engine, let sit for 30 seconds and then restarted without any issue. I was now able to ride the remainder of my 700 miles back home to Florida with no issues.
Was wondering if anyone else has ever had this issue with the Pedal Commander. This thing is so awesome and the short time that I had to ride without it was such a drag. I realize that it doesn't add any horsepower, however, the responsiveness you get with it installed is well worth the price.
Thanks,
Following this as I just added the Pedal Commander to my '21 RT. Only (1) ride w/it so far but no codes. Might be helpful to know what year/model you have.
I have ~3000 mi on my PC (2020 RT base) trouble-free. The Google Gods say: What the P2135 code means. This particular trouble code indicates that the Power Control Module (PCM) has detected an erroneous reading regarding the voltages transmitted by throttle position sensor A or B, the accelerator pedal position sensor and or the actual throttle plate.
So it does appear that either your PC is hosed or you may have a bad connection. Check for full plug-in and if a pin was pushed back in either plug.
