Peacekeeper6 Mod Thread
I will attempt to document all of my modifications on our 2018 Spyder RT Limited, complete with difficulty level from a scale of 1-4 (1 being the easiest) and some tips that have helped me during installation.
1) Trunk Mounted Double Flag Holder Set
Difficulty Level - 1
Tips - This was probably THE easiest mod I’ve ever done.
Notes: I really like this mod, because I thoroughly believe that every biker
should be patriotic and fly the Stars and Stripes. Since I served with
the 101st Airborne Division (Air Assault) out of Ft. Campbell, KY, I’ve
decided to also fly the Screaming Eagle. I’m both proud and honored to
fly these colors on our bike.
2) Lamonster Magic Mirrors
Tips - Do NOT be afraid to knock the living crap out of your original mirrors.
Also, these magnets are STRONG. Do NOT let them hit each other
because the possibility of breaking them is very high.
Notes: This is A MUST mod. Anytime you perform an oil change, light
upgrade, etc, you WILL have to remove body panels, and the side
view mirrors are the first to be removed. Also, these magnets
significantly reduce vibrations and improves visibility. If you can
only afford one mod, make sure this is the one.
3) Next Gen LED Bumpskid
Difficulty Level - 2
Tips - Jack up the bike to provide some much-needed room. Use some
C-clamps to immobilize the front of the bumpskid for accurate hole
placements. Use SHARP drill bits, especially when drilling through
the metal frame for the rear bolts. BE CAREFUL you don’t hit any cooling
system components while drilling, so TAKE YOUR TIME.
Notes: While this isn’t a necessary mod, I feel that it’ll save body panels
in case I accidentally hit or run over objects. This was my first LED
component, and I was extremely impressed with the quality of its
light output. It has inspired me to upgrade my stock headlights and
fog lights.
4) Lamonster RT Spyder Cuff with Lamonster Approved Phone Holder
Tips - Use the “rubber band” for a more secure install. I installed it
on the right side because (1) I’m right handed, and (2) I feel that the
left side of the handlebar already has enough buttons and levers.
Notes: There is a reason why this is one of the most expensive cup/phone
holders in the market. The quality is second-to-none. In addition, this
was my first RAM mount, and didn’t realize how versatile and fully
customizable it makes your bike. This Lamonster product is very
well-made, and gives me confidence in purchasing other items from
them in the future.
5) Spyclops II LED Light
Tips - Measure the LED strip and cut it at the indicated line. Power can be
tapped on either side, so think about how you’re going to place it under the lip
of the front hood. Ensure it clears the front of the hood when opening and
and closing it.
Notes: The bumpskid LED caused me to purchase this item. I thought about
getting the ones that install on the A-arms, but I felt that that it would be over
the top and didn’t like the way it looks as compared to the Spyclops. Plus,
it looks cool, lol.
6) Lamonster Ultra Bright LED Headlights
Tips - I didn’t have a sharp knife or a proper bit for my Dremel, so I drilled a
a hole ¼ inch from the edge with a bit that was the same width of the wire.
Then, I used a pair of tin-snips to cut the rest of the plastic off. Quick and easy.
Install the controller box OUTSIDE the cap because there’s no room inside. Use
strong Velcro to secure it AT THE BOTTOM half of the cap where it curves downward.
Notes: This mod is not only aesthetically pleasing, but it provides an added
safety feature that cannot be stressed enough. I haven’t tested it out at night
yet, but I’m quite sure it’s a definite improvement over stock. I like the fact that
it doesn’t have a fan that can fail, which is probably the reason why it’s more
expensive than other LED headlights. You get what you pay for, right ??
7) Lamonster Ultra Bright LED Fog Lights
Difficulty Level - 3
Tips - Start with the right side first to familiarize yourself in this bitch of a project.
Use a stubby flathead screwdriver to pop off the cap. It’s a straight install from
here on out. The LEFT side, however, is where it gets interesting. Popping
the cap is probably the easiest thing here. Again, unless you have dainty-
sized hands of a 5th grader, you’re gunna be cussing yourself and the BRP
engineers to no end. I must’ve spent about 2 hours trying all different ways to
install the cap back with no success. I decided to leave it off because I came
so, SO close to throwing the cap 98 mph out of my garage and onto the street.
I’ve decided to keep the cap and will reinstall it when I take the frunk off in the
future should I decide to upgrade to the Baja Ron Swaybars. If ANYBODY has
a tip in reinstalling this cap, please let me know.
Notes: This mod really wasn't THAT necessary, but it really bothered me when
the fogs were turned on, and it was the only yellow light shining through
a sea of white LEDs. It also bothered me that the black plastic cap was kicking
my ass, but I'm sure it'll find its rightful place once I take the frunk off. Oh well,
sometimes you win, and sometimes you lose.
8) High Mount Brake/Run/Turn Taillights with Plug-n-Play Harness
Difficulty Level - 2.5
Tips - Measure twice (thrice, quadruple), drill once. Once you get over the fact
you’re gunna be drilling a hole in your $25k bike, the rest of the install is pretty
easy. Tons of parts to take off and reassemble, but it’s pretty fun because I feel
like our Spyder is like LEGO for adults, LOL.
Notes: Really, BRP should have designed something similar from the factory.
This mod is one of my favorites because, as stated above, it was fun taking
apart the rear end of the bike for the first time and putting it back together
WITHOUT any issues. No tools were thrown from my garage !! Plus, the level
of the lights is just right for the vehicles in the back, a DEFINITE safety
feature. The Lamonster wiring harness made this install quick, easy and painless,
so if you absolutely HATE wiring, the added price is worth it.
9) Diamond R Passenger WEB Armrest
Difficulty Level - 1.5
Tips - Prior to removing the seat, put a piece of cloth on top of the dreaded Black
Hole in the back to prevent accidentally dropping a nut or bolt into it and never
seeing it again.
Note: It was a toss-up between these armrests and the BRP ones. I like these a
touch better because it's longer, which offers more comfort. I spoke to the owner
of Diamond R when I was ordering it, and he was REALLY nice. The armrest and
baseplate are robust, and the chrome pieces adds some class to our bike.
Disclaimer: If you are wondering about my mechanical skills, I can safely assure you
that I am NOT a mechanic by trade. I own a variety of cars/trucks, and am able to do
simple DIY projects like oil and oil/air/cabin/fuel filter changes. I own a 1/2-ton Silverado, and have
replaced the radiator, alternator and in-tank fuel pump. I also own a 3-Series BMW
and have replaced window regulators (4 times !!), radiator (once), thermostat/water pump/
expansion tank (twice), brake pads/rotors (twice), in-tank fuel pump (twice). My BMW,
while it's been a GREAT car to drive, is NOTORIOUS for weak window regulators and cooling
system. It has given me a good reason to learn to DIY many projects and have saved
time and money by doing the jobs myself.
Also, I'd like to thank the many Spyder DIYers who have documented their work on YouTube.
Without your help and guidance, owners like me would have a very difficult time in many
of our mods and DIY projects.
Nice write-up Lou. Skiing this week????
Thanks Lew.
My grandson is going to spend the weekend with us. Plus, my season pass has blackout dates this weekend.
So to answer your question, no I'm not going skiing. I have a few Fridays off coming up, and will text you when I'll be going up to Rose.
Dang, wish I was retired....
Where do you get the time to work!
I work Monday to Thursday. These mods were installed in the last 2 months or so during the weekends. They're really not THAT time-consuming, and I don't use any powered screwdrivers when taking off or placing back the tupperware. I find it very therapeutic to take each screw off each panel by hand and reinstalling them in its original hole. Call me "anal", but I'd rather be called "thorough" or "precise", LOL.
Not sure how long it has been since you installed the foglights. The cap should be installed to prevent water and debris from entering the inside of the foglight housing. Once inside it is very difficult to clean.
I just installed it last Saturday, 2 days ago.
I don't really like to ride in the rain (I'm a fair weather rider with no real rain gear), so that's not a concern. I'll try my best to avoid any puddles or wet spots on the road.
I did try to unhook the left fender to gain a bit more access, but I think my bumpskid was preventing it from moving. Because of this, I didn't bother to unhook the air intake. Like I said, when I decide to remove the frunk for the sway bar install is the time I'll try to reinstall that stupid cap.
I should just run a few strips of duct tape across the opening in the meantime, lol.
10) Lidlox Helmet Lock (pair)
Tips - Pretty straightforward install. My 4-year old grandson could've probably put this on for me.
Notes: Looks to be a high-quality product. It's my first Lidlox, and I might buy one for my Harley. It's really nice not having to put our helmets in the compartments, although I worry about drunk people at rallies using our helmets as makeshift trash cans, LOL.
(This mod is no longer installed and was replaced by Lamonster IPS Bar End Caps)
I would worry more about the drunk folks using the helmets as barf bags rather than trash cans.
We were in Branson, Mo. last summer. Beautiful day, went into a restaurant to eat dinner. While in there, a thunder cloud full of rain passed over. Our helmets were FULL OF WATER. Since it was a very warm evening we just poured the water over our heads and put them on. Ya just gotta do what ya gotta do. :thumbup:
Welp, I just ordered the Two Brothers S1R slip-on exhaust.
ANYTHING sounds better than that OEM can that sounds like George Jetson's car, LOL.
I'm hoping that the cat will help muffle the sound and makes it bearable at highway speeds. At least, I'm doing my part in keeping our breathable air clean....
11) Two Brothers S1R slip-on exhaust
Tips - I found that it was easier attaching the slip tube to the muffler with the supplied hook springs first prior to connecting it to the bike. Removing the nut that mounts the OEM muffler was tough with just a regular-length ratcheting wrench, so try to get more leverage by attaching a metal tube at the end of the wrench. I didn't have a tube, so I used Vise Grip pliers and that did the trick. Also, the Vise Grips helped to attach the TBR clamp to the supplied TBR muffler hangar bracket.
Notes: I'd have to say that out of all my mods so far, I absolutely LOVE this one. IMO, it makes it sound SO much better than the OEM muffler. It's not obnoxiously loud, probably because I decided to keep the catalytic converter. (Hey, I'm just doing my part in keeping noise and carbon footprint at a minimum, lol).
12). Wrap My Spyder 758 SI and Phoenix decals
Difficulty Level: 1.5 (the bigger decals take more skill and technique).
Tips - TAKE YOUR TIME !! Otherwise, it’s not very difficult at all.
Notes: I LOVE how it just transforms our bike into something more eye-catching and unique. I tried to install the BIG Phoenix on the frunk, but ended up botching it. So I removed it (with choice words, I might add) and instead installed the smaller Phoenix, which was A LOT better. Going to be interesting to see how they’ll last.
Great write-ups Lou. I have been buying parts from the folks at Diamond R since the early 2000s when all the made were Royal Star accessories. Met them again at D3WR last Summer and bought a Wounded Warrior cup holder and cup from them. I had clamp on flag holders on the luggage rack but they were always tilting. The trunk mounted poles look nice and are always upright. U S Flag and a Temple Riders Flag. Although not a vet I have always had Old Glory somewhere on my bikes. I have the black out wrap from Wrap My Spyder on the lower part of the windshield and it looks good and has held up to bugs and road debris very well so your wrap should do very well.
Thanks Paul.
Yeah, can't remember the name of Diamond R's owner, but he was very personable and patient that I just HAD to give him my business. After a few months with it, I wish there was some sort of locking mechanism so the armrests doesn't move once it's set at a certain position. Other than that, I have been getting a lot of compliments with it.
Many are also digging the decals from Wrap My Spider. I'm hoping to get some custom ones with our names, kind of like the names of fighter jocks stenciled on the side of their F-15s, F-16s, F/A-18s, etc. Hoping that someone will read this post and point me in the right direction....
Thanks Paul.
Many are also digging the decals from Wrap My Spider. I'm hoping to get some custom ones with our names, kind of like the names of fighter jocks stenciled on the side of their F15s, F16s, F18s, etc. Hoping that someone will read this post and point me in the right direction....
WrapMySpyder will custom make something for you if you have something in mind. Just give Pete a call. As long as your not in a rush.
