Passenger Backrest Install
jtonga
I'm in the process of installing a passenger backrest on my 2014 RSS, and I'm having difficulty sliding the receiver into the frame channel. Was wondering if anyone had a similar experience, or did I just get a reject of a part. I was thinking of maybe grinding down the receiver a bit, what do you Spyder folks think? I've attached some pics of what I mean. Much thanks, Joe
View attachment 164062View attachment 164063View attachment 164066
:dontknow: If OEM it should fit just fine maybe require a bump or two but not grinding or shaving unless is in the instructions with proper locations:lecturef_smilie: looking at the pics I see what looks like wire loom holders pressed thru on 3 sides. They may simply need pushed out till receiver is mounted then put back in:dontknow: again should be in the instructions :thumbup:
Thanks for the input. I thought it was getting caught up on the wire holders too but it doesn't even make it in that far. The slide receiver won't clear the (not sure the name of the part) the piece just before the frame channel. I might just try hammering it in with a rubber mallet? Thanks again
Any update?:dontknow::dontknow:
Update
Yes, and sorry for not posting sooner. It was a REALLY tight fit, but the rubber mallet worked great. The instructions said that it would just "slide in", which wasn't the case at all. But now that it's installed, I am very happy with it (my wife even happier)! Thanks for your help :2thumbs:
