Y Rider
I have a 2011 RT Limited. I installed the ESI Brightside LEDs, HMT Brake light and LED mud flaps. All works well and I am very happy with the results except for a minor issue I ran into when removing the Middle and Top Side Panels. Behind the Top Side Panel are two rubber grommets. One was missing so when putting all back together I used one from the Middle Side Panel since it would be easy to replace.
When I went out to the BRP On-Line parts store to order a replacement I found out according to the 2011 parts list the Middle Side Panel should be using a "Grommet Assembly" part number 705005055. This uses a rubber grommet with a metal plate overlay. Looks to be a better design to keep from loosing grommets. However, the actual grommet used on my bike, "Oval Washer" as described in part list, uses part number 705005156 which is the number used in the 2010 model. According to the parts list the 2011 models still use the 70500516 Oval Washer for the Top Side Panel.
So I am a little confused. Are there different versions of 2011 Spyders that use the new and old versions of the "Oval Washer" for the Middle Side Panel?
I need to order grommets so I guess I'll order the 2010 grommets for my 2011 bike. :dontknow:
