h0gr1der
Looking to find the part number of the two short T30 Torx screws used on the lower side panel, one at the lower front capturing the water deflector and lower panel, and one under the seat all the way at the rear. Looking through the Can Am on-line parts diagrams for the body panels, I only find two references to a bolt shorter than 20mm.
2018 RT Limited SE6
09- Body And Accessories - Panels
Item 5490 Torx Truss Screw M6 X 12 P.N. 250000767 (I think this may be it)
Item 5660 Torx-Truss Pt K40 X 16 P.N. 250000759
Any help would be appreciated. Those drawings are hard to cipher!
2018 RT Limited SE6
