kingharley
Anybody out there that has broken the cheesy break cable yet, I did. But I see they have a different part # now. I haven't contacted the dealer yet. But, :dontknow: just wondering if others have had the same problem. Thanks
Ryno said:not broken yet but I feel that it is not far from it, I just leave it in 1st.
Lubricate the cable and the release mechanism, and be sure the rubber boot didn't get hung in the cable. Makes it much more reliable!SPYMAN said:Same here leave it in first, Mine seems to get jammed when it is set & have hard time releasing the brake!
SPYMAN
:agree: I've got #3550, parking brake (not break!) works great!trikester said:I wonder if Can Am has made a change in this along the way. Are these problems spread throughout the serial numbers or just the early ones. I have #3003 and the barking brake has been working flaw less. Quick engage and quick disengage.
Frank
i ve been reading a lot on problems with the parking brake sticking, since i work
for a can am dealership, we've resolve the problem by lubricating the parking brake cable
it as a tendancy to stick in the enveloppe, do not use w-40, try using a silicone base lubricant
Others have advised to not use WD-40 but to use a lithium based lubricant. I can't support one over the other, just passing on info. I use 1st gear as my parking brake so my real parking brake has not developed any issues.
where exactly are u lubing it? I need to try this on mine..it sticks too
Crawl underneath your Spyder with a flashlight and operate the parking brake by hand while viewing the mechanism. Lubricate any place you see two pieces of metal rubbing together.
Regards,
Mark
I'll have to try some. First, I'll have to find it somewhere. Don't recall seeing it.
