wmh9680
Good Morning, hope everyone is out riding, been a little rainy here in Chicagoland lately.
Just had my 14 RT LTD up on the lift to check everything out. It seems when I changed the rear pads I guess I didn't locate the cable properly or it came out. The two adjusting nuts were not located in the slot where they should be and the cable had tension on it because it was running at a slight angle. The rear wheel seemed to not be as free as I thought it should be. I thought my gas mileage had been a little low also. I took the spring off and rerouted the cable the right way and left a little slack in the cable when I tightened it back up. I thought it rear wheel still was a little tighter than both fronts, is that normal? It was dark and getting late so I will look at it again in the AM. I know the brake needs to be working on the semi-auto so it will not roll on you when it is not running so I got to get it right. What is the correct way to adjust the parking brake? I found this on youtube --- https://youtu.be/qnIgEZ1pgRw. Thanks, Mike
