Panel Screws
maliamd
I am having difficulty removing the top side panels. What tool do you use on the screws?:helpsmilie:
The sliver ones do not come of just for looks. Look on this borad and you will find how to remove all. Just tpye in the surcharge spot forit
Little checking..!!
if you search panel removal you will find videos on the whole process. This will help you out. I have RS and there are no phonies...:thumbup:
The silver security screws should not be removed. They hold the pins that fit into the rubber grommets. Instructions for removing the panels should be in your manual, and the necessary tools in your toolkit (although other tools may work better or faster).
