JKMSPYDER
]I have a friend that recently bought a pre-owned 2013 RT SE5. She wants me to show her how to change the oil. I downloaded the 2013 owners manual and discovered that a lot of panels have to be removed to get to the plugs and filters. The manual says to remove the LH side panel, bottom front side panel, and bottom rear side panel. When I get to the part about removing the LH bottom rear side panel it says to remove the middle side panel, the top side panel and the rear side panel. I don't see a photo or description of a middle side panel. Are there any shortcuts that anyone can suggest? I think I am also supposed to remove the bottom plate under the oil tank. I own an F3-S that requires much less panel removal.
