F3Spyderman
The outside (ambient) air temperature gauge on the multifunction gauge cluster of my F3-S always seems to be quite inaccurate. It always seems to read 4 or 5 degrees centigrade higher than the local air temperature. I realise that sometimes reading can be high due to sun shining on the Spyder or after a ride where heat from the engine may be drifting around the temperature sensor and I take that into account. I'm talking about when the Spyder in sitting around cold and unused or when riding on a run where you would expect reading to eventually stabilise to local air temperature.
Looked in the workshop manual to find the location of the temperature sensor but could only find stuff relating to the air intake temperature of the fuel system.
Any help or advice regarding the temperature reading would be much appreciated.
Paul
Paul
