That's pretty cool-looking! :clap:
What is it? :dontknow:
How many does it sleep?
Does it have a full kitchen and full bathroom?
Bob, the T@B camper has everything the big boys have - 2 burner stove, AC/heat pump, furnace, 3-way fridge, sink w/5 gallon water reservoir, queen bed (bigger actually, almost a king), bed sets up into a U-shaped dinette. You can get the T@Bs in several floorplans including the classic teardrop where the galley (kitchen) is in the back, outside. We got the floorplan with the largest bed due to our size, I'm 6'3" and used to weigh 285 (but lost 75+ pounds over the last year!).
-Alan
The downsides are the towing weight, without cargo, is well over the 400 lbs spec for the Spyder. Cargo will just increase the overweight amount. The tongue weight, empty, is more than double the spec limit, 90 lbs vs. 40 lbs. These are the specs for the 2013 but it looks like the 2014s are the same. I personally think the MyPod would be more than the Spyder can handle safely in an unusual driving situation, like maneuvering around hazards or fast braking.We're considering a MyPod. Made by Little Guy Teardrops (golittleguy.com). They weigh about 500 pounds but I've seen people towing much heavier with Spyders so think it could handle it easily. The camper in my picture is a T@B (TAB) also made by Little Guy. It weighs about 1700 pounds so the F150 in the background is overkill for towing it but the truck allows us to bring all our gear so works out well.
http://www.golittleguy.com/the-mypod-has-arrived
Some of those little beauties ARE towable by a bike (or Spyder!)! :2thumbs:[/QUOTE
If any body could come up with it Bob I knew you could and you didn't disappoint. MyPod Hitch weight is a little heavy at 90 # but I don't think the weight is a problem. Pretty nifty eh. And best of all the one in the brochure matches my red RTS! Wouldn't that be a combination?
Jack
we send ours ahead..made by phone..it's called a reservation..!! :roflblack::roflblack: but some of those look like they would work nicely for the camper type..!! :2thumbs:
