Original tires 14 rts
duke50
Got almost 6000 miles miles on rear tire
with 3/32left on tread on original tire
Should I change now or keep riding
As the tread wears down; the chances of losing traction starts to go up exponentially... :yikes:
I'm all for safety, and I'd change it.
Depends..!
14's had a batch of softer compound tires which did not last long. They later changed to the original compound and these get much better mileage, if anyone would try them. If you were to go to the oem just make sure the are pre 14...late 14/15...:thumbup:
I got 8k miles and changed them at spydxrquest. New tire should get 10k Don't take chances on tires,
Replace when they get worn down. Early 2014's had a special softer rubber compound that wore down faster than prior versions.
4K to 6K was common for a lot of those posting. I got 8,900 out of my first rear tire on the 2014. I am at 20,000 miles (11,100) on the new one and think I will get another 3K or so before a change is done.
All prior :spyder2::ani29: were in the 13K to 15K range for me. I am talking OEM Kenda's here.
I am a new spyder owner. Just over 1000 miles. Do most people go back to dealer for tires or any motorcycle shop?
Sent from my SM-G920V using Tapatalk
