farmerold
real cold :f_spider: had coolant leak on 14 rt. When temp drop's in single digit's is only time it would leak. When it was warm didn't leak even when they pressure tested it Finally did pressure test when it was real cold left out side leakage show had to replace five hose clamp's. Seem the factory clamp are not tight enough my mechanic said where hose goes on to the plastic fitting the plastic would shrink when real cold thus the leakage. replace clamps pressure check out in the cold didn't leak. Brought home today first ride this year ah back in the wind again.:clap:
