bluestratos
Lol... I have a 300 watt Rockford Fosgate 4 channel amp being driven by the hi level imputs from my stock radio. This puts out great sound and plenty of power as can be attested to by the 5 speakers I have blown (Polk 45 watt rms units) I have some new speakers coming that will be better suited to the power of the amp but in the mean time my bass woofer blew (had a 100 watt amp). It really rounded out the sound but had to be turned all the way up so I replaced it with a 300/600 watt unit.
I fired it up today and started adjusting the gain but even at full gain, full base boost and max bass volume it really puts out very little until the radio unit is pushed to max and then it is not adding much. I have the amp being fed by the same speaker inputs from the first amp so it it just Y's off the radio out put wires and it is going into the high level input into the base but it almost seems like it is not getting enough power from the head unit.
The amp has RCA inputs but to use these I would need to add hi level to RCA input converter. The amp does say it works best with RCA inputs so... what do you think?
