MouthPiece
Banged Up Member
When I had my 2010 RT-S everything seemed so simple with respect to when I would have an oil change and/or maintenance service. I could gauge by every 3,000 miles or increments. However, with the new extended oil change parameters, I personally found when to do what a bit confusing.
It seems now, and please someone correct me if I'm way off base, that the oil change (note this is a deceptive label because there are many other things that are required to be performed other than oil change) is for every 4,700 miles. If you ride more than 4,600 miles annually, then your true maintenance schedule (which is performed in addition to the oil change and the other things mentioned above) is or appears to be 9,300 miles, 14, 000 miles or 2 years whichever comes first and 19,000 miles or 5 years whichever comes first.
Is this basically correct? Thanks for any input.
Chris
Chris
