jmcbow
Recently installed ESI's HMT brake light. Nice looking product, really looks stock after installation, super bright, feel better knowing it's back there when I step on the brake.
However, installation was another matter. I discovered on my RT that the multi pin connector was buried down and behind the turn signal assembly, and there wasn't enough lead length on the wiring to pull it out and work with it. Subsequently, I was forced to remove the turn signal assembly which meant dis-assembling much more of the RT then the instructions indicated. What should have probably been a 30 minute job, turned into about an hour and half. So don't be too surprised if you discover that you can't get to the multi pin connector by just pulling off the tupper ware that wraps around the back of the RT . :gaah:
