NMN tail/brake light install tip
SSPSpyder
Installed my NMN handlebar inserts, rear peg adapters, and center tail light - all good stuff! - and wanted to pass on a little tip/trick for the tail light install...
The tail pan screws are a bit of a PIA -
instead of removing all 7 screws and then removing the tail pan (plastic pan under the seat), remove the 5 screws closest to the rear and then pull down the pan and tuck it under the rear fender. It will hold there and give you plenty of room to hook up the wires. Reinstall the 5 screws and you're done.:thumbup:
