IdahoMtnSpyder
Well-known member
Madison, a couple of things you're probably not aware of as a new owner. Contrary to how bikes and cars have functioned in years past, a Spyder will not start if the battery voltage drops to below 10.5 when you hit the start button. If you had only 11.8 to begin with I'm sure that's what happened. Second, from posts that have been here in the past, be very careful with the terminal bolts on the battery. They are hard to get wrenches on to turn and easy to lose. You might search the forums for some comments about that. In 2013 the battery was moved to the front and much easier to work with.
There have been lots of comments about alternate batteries to the OEM Yuasa, but the general consensus is that as far as value for money and overall quality the Yuasa OEM battery is about the best choice. If you're knew to this world don't waste your time looking for anything better. There are some, but not easy to find and definitely not easy on your wallet.
Now, as far as tires go, that's a whole nuther story!!!!! You'll suffer brain strain to the max trying to figure out what's the best way to go. One of the best cures for insomnia ever invented are tire threads on SpyderLovers! :roflblack:
