New to 2018 RT Ltd - Park Brake, Battery Tender, & VIN Questions??
DRFab
Hello everyone!
I'm new to this site and little overwhelmed on how to navigate my way around so please bear with me.
Just purchased this gorgeous pearl white bike with only about 4000+ miles on it. Still trying to get familiar with the bike as this is my first Can-Am purchase. So off I went excitedly to AAA to register vehicle and have it officially under my name. Since the bike was previously registered in another state, we could not complete the transaction as they had to inspect the VIN and the engine number which I had no way of knowing where it was nor where to find it. So I was given a 30-day temporary permit. That was the first issue.
Then as I was leaving I started the bike but the parking brake wouldn't release so i was stuck and couldn't figure out what to do. That was the second issue and a bit frustrated at this point. After doing some research, calling some m/c shops in the area, trying to make sense of the manual, etc.. i was finally able to get assistance from a really nice service tech from a dealership in San Diego. He gave me instructions on how to release the parking cable so I could ride back home. What I thought was a simple errand to start my day ended up quite not simple for a Can Am neophyte. Anyway,........
Question 1 - Not sure what caused my PB to get stuck, was my battery possibly on low voltage such that some sensor might have tripped or not function correctly?
Queston 2 - Thinking of getting a battery tender to make sure battery is well maintained and charged. The previous owner had it mostly parked unused. Should I get a Deltran battery tender junior plus with 1.25 amp or would the regular Deltran battery tender junior suffice?
Question 3 - How do I handle the part where I have to show a DMV person or a peace officer to inspect and verify the VIN and engine number? Do I try to remove the panels to see where the engine number is located then ride it bare to either DMV or local police office for inspection? I found where the VIN number is located so not an issue there.
Sorry for my short novel but would really appreciate your input/suggestions.
Thanks.
Danny
I just registered my new out of state RTL in CA. I used a DMV agent who was very helpful. She got down on her knees with a phone camera to get a pic of the VIN number. I have heard stories of DMV staff refusing to look for a VIN that isn’t plainly visible.
We never did find the engine number. Apparently on the 2021 RTL is requires some plastic removal. She was okay with certifying the bike with the engine number taken from the original title
My experience probably isn’t much help to you but good luck
Hello everyone!
Thanks.
Danny
I have the same year bike, in the same color.
Good choice !!
To answer:
(1) I learned the trick is to not put too much weight on the brake pedal prior to pushing the parking brake button and engaging it. I believe that if you really stomp on the pedal and pushing the button, the parking brake motor has a very difficult time releasing the brake when you try to disengage it.
(2) I have the regular Battery Tender Junior. It works really well, and honestly, I don't see why you would want to spend more money on the Plus model.
(3) Taking a pic of the engine number is probably the easiest way to show an officer. Iirc, I didn't have to take any panels off, but I *could* be wrong. Refer to your owner's manual (you DID get the owner's manual, right ??) for the right answer.
Anyway, good luck and have fun both riding and modding your Spyder !!!!
(Lemme know what mods you're thinking of doing, and I'll do my best in answering questions you may have, including any installation).
Peacekeeper6 is correct -- light foot on brake when disengaging/engaging the parking brake.
The Spyder has many electronic modules and motors (parking brake is one, steering is another) that really really need a fresh battery with low internal resistance. Your battery is four years old with bad maintenance. Eliminate one worry and treat your new Spyder to a new battery!
Did you get an owner's manual? Read it before your next ride. Read it again before the ride after that. There are many subtleties in this rather sophisticated machine. Best you know each other.
Maybe I should go to DMV instead and try my luck. The AAA rep was pretty adamant on seeing the engine # otherwise would only give me the temporary tags. Then she gave me a business card of some local "vehicle inspector". Called that number but told me they don't inspect m/cs. I'll try DMV next but first will need to deal with my parking brake issue. Thanks for your input.
Much Appreciated
Yes sir, totally agree.
Will get familiar with the a.)manual and b.) new batteries.
Much appreciated.
Thank you.
Thank you so much. I'm taking all these good suggestions and glad to be part of this awesome community.
Ride safe.
Peace
Which Yuasa battery/model number should I purchase? Looking at Amazon but willing to get site suggestions on where to purchase.
Thanks again.
Thanks again.
Yuasa YUAM7250H, purchase from a local store or Amazon.
Just make sure that you properly charge whatever battery you get BEFORE you install it!! :lecturef_smilie:
Most vehicle batteries are supplied with a nominal charge, if that; and they'll need a good full charge before you install them or they'll either fail prematurely &/or take ages/lotsa hours of highway speed ryding before they are even close to fully charged by the onboard charge system! :rolleyes:
To find the VIN stamped on the frame turn the bars full left then on hands and knees look at the part of the frame where the red arrow is in the first picture. It is just above the front lower A-arm mounting point. The second picture is what it looks like.
As Peter said a proper charge is key to battery life and performance. With a good charger (4 amp is about right for the Spyder battery) charge at least overnight with 24 hours being better. Some lessons-learned:
1. The battery is heavy and the workspace is cramped.
2. The battery cables are 6AWG and don't have a lot of strands which makes them stiff. And did I mention the workspace is cramped.
3. The battery holddown plate almost falls out for removal and if it only takes you an hour to put it back in place ... well I'm envious.
4. A small LED flashlight is your friend.
I had to get the engine number off a friend's 2016 as he was back in a Northern state trying to title and register it. Remove the left hand pull off tupper war panel and put my phone/camera around the back corner of the engine.
Isn't the VIN still on a label on the left swingarm? Of course if the DMV insists on seeing a stamped VIN then that won't do.
My PB issue on my 18 was adjustment.Unless you are on a hill there should be no need to put any pressure on pedal to engage or disengage.Have had it off and on many times without mounting the bike just to move it in garage.A 12mm wrench did become a permanent rider!
