DragonSpyder
Just installed the new Toyo tire since neither of the local dealers were willing. Removing the rim/tire and replacing was fairly simple once you have the correct tools (36MM sockets).
First thing I did was weigh the tires side by side. The new Toyo weighed 16.2Lbs and the bald stock weighed 18Lbs. The stock was probably a Lb or 2 heavier when new. I pushed down on each to check the sidewall and they seemed similar. The tread was a bit stiffer across the top as it was easier to depress the middle of the stock tire. This could be partly because of loss of tread.
Took the tire to the local tire shop and they mounted the tire only to find out they cannot balance. Found a MC repair shop to do the balancing. Tech. said it was close enough that I probably did not need to balance.
The ride is much smoother with the Toyo, especially 2up. That is with 32Lbs of air in the tire vs 28Lbs in the stock tire. Traction seems to be better on dry roads but have not ridden in the rain yet.
The only issue I have with the new tire is wandering. Not sure why but for some reason the Toyo tire makes the Spyder want to wander more, especially on uneven roads. It actually feels a lot like the stock Spyder did before I added swaybar and did a slight toe-in on the frontend. This is with 32Lbs so I am going to try more and less pressure to see if that makes a difference. I have to believe this is due to either more traction on the tire or sidewall flex, which should have been similar to the stock based on my preinstall comparison.
If I can stop the wandering issue this tire is a win/win. I will keep everyone informed as I try different pressures.
