BLUEKNIGHT911
Sadly Passed Oct 2024 - RIP
So I wanted to try a CHUCK roast in my pressure cooker .... only none on sale, but they did have a BOTTOM ROAST, so I bought that ... 5 lbs. ... It was waaaaay better than I expected .... made a slurry of 2 tbls. of Corn Starch using COLD red wine ... (or water) .... made TWO pkgs of dry brown gravy mix with THREE (not TWO) cups water heated in a very heavy fry pan and seared all sides of the roast .... de-glazed pan with some red wine. Poured that into Fry pan and heated to BOILING .... stirred in Corn Starch to thicken ..... put ROAST into Pot, then poured gravy over Roast ... I like carrots so added a 15oz. of Drained carrots to gravy and some onion slices .... Brought pot up to Temp then lowered heat to minimum setting on stove and cooked for 1 1/2 hours. ..... Let stand for 15 min. to release All THE PRESSURE .... THEN OPENED pot, took out roast put into a bowl .... I have an EMERSION BLENDER and used that in the gravy.... I Loooooove Potatoes so I peeled SIX - cut them in half and put those into the gravy mix.... re-covered the Pressure cooker and brought back to Temp. ... again lowered gas and cooked them for SIX minutes .... let sit to remove the PRESSURE ..... since I wanted to slice the Roast, I had to let it cool .... otherwise it would have fallen apart. ... You can season to taste with what you like before cooking. .... Then it's simply heat and eat ..... Enjoy ....Mike :thumbup:
PS: If you want the GRAVY thicker, I have used "Instant Mashed Potatoes" with great success, just add a little at a time to gravy while stirring vigorously ...
PPS: Walmart sells a LOW SODIUM version of the "Dry Gravy mix" for only $0.48 per package
