New Pedal Box Install (blue tooth version) - No noticeable difference
Arcamguy
I finally made time and installed the Pedal Box controller (blue tooth version) on my 2022 Rt Limited. I did it with the assistance of Pierre's YouTube video, so the process was deliberate and slow (great video). The most extended portion of the installation was determining the best place to mount the controller. I kept it next to the two new connections. I was mounted to the black bar where the original wiring was clamped.
I did program the pedal box as instructed (3 times). So far, everything has gone very well and relatively easy. After downloading the Play Store app, I paired the pedal box to my phone. This is where things didn't go very smoothly. I did pair it to my phone, but it reacted like I still needed to get an app, but I was paired.
I went for a ride, no fundamental changes at all. I tried all levels, city, sport, and sport +. So I came back home and tried reprogramming it again. I went for another ride, and still no changes.
Do you think BRP connect/Go is interfering with the Bluetooth signal/connection of the Pedal Box? I don't know what to do at this point. I need help.
Thanks,
Arcamguy
Arcamguy, the difference is significant! So something is wrong.
I had to delete mine on my phone and reload. Sport +2 is a great setting, +3 or Sport+ 1,2 or three - hang on!
I have a Pedal Commander which is essentially the same product/does the same thing, and the difference was night and day. There's something wrong with yours if you can't tell a difference.
I too suggest a re-install.
I fitted mine and to my best ability did the program thingi.
Went for a ride then got a limp mode bout 4 minutes into the ride, I went home and re-did the install. This time it held.
Night and day and entirely noticeable.
No more lag and burble ok I will think on this before I had throttle response.
BRP Go only operates via the cable from your phone, Arcamguy. BT operates independently and wirelessly of that…….. I have zero issues on my ‘21 RT with my iPhone connected to the RT Bluetooth, and using the Pedal Commander app on my phone to change settings on my Pedal Commander. I am not running Pedal Box however, so this post is just info that phone to RT BT doesn’t impact phone to Pedal Commander BT.
Pete
Thanks,
Arcamguy
I wouldnt bother with the phone, just use the controller itself, it is water proof and mount it where it is easily to use, mine may go on my handlebars
