New member with 2012 RT & Code P1174 - any ideas?
drewdog
New to site, new to me used 2012 RT. I had some minor problems that I worked out. I came home yesterday, with the engine light on. I checked for codes and found P1174, System too lean bank 2. When I bought the bike, the purge tank by the fuel filter was disconnected and bypassed, I don't know why. Anyone know if this would cause a running lean code to pop up?
I got that code a lot with my 2011. Mine was caused by the purge vale sticking. You stated that yours had the evap cannister removed. Make sure the purge valve is still attached and plugged. If purge valve removed it will generate that fault. The other possible cause is a bad O2 sensor on the rear cylinder exhaust. Of course, there other possible causes: cracked intake manifold, dirty injector. Bruce
Do you know if the rubber MAP sensor hoses have been changed to silicone. These are a known issue and should be changed from rubber to silicone.
Thanks for the input, the canister is plugged off, but I'm going to relook at the purge valve. I might try putting the canister back in line and see what happens. It idles at 1300 to 1400 rpms, is that about right? And do you know if it will hurt to run with it being lean? Thanks
Yes, 1200 to 1300 is normal for your motor.
The can should be disconnected, and the valve should be plugged; just make sure that the vac hose to the engine is plugged and tight. The can itself can be ripped out and set to the side. I just did mine this summer, that's what I did, and I'm glad I did it.
Hi, I'll have to check that out, but I doubt it. Where is the MAP sensor located?
Look on the left side of the Spyder up by the throttle bodies you will see a little black with a hose coming from that to the throttle body. There is one kind of hidden on the other side going to the front Throttle body. My silicone hoses are a reddish color. If yours are anything but black then they have been changed. If they haven't been changed, now would be a good time. I bought mine from NAPA, they are 3 mm vacuum hose in silicone. When I changed mine in 2015 I paid $6.00 for a package. When you take off the old hoses, preserve them and cut the new ones the same length.
Unfortunately ongoing
https://www.spyderlovers.com/forums...ring-not-constant-code-amp-check-engine-light.
Purge was replaced, evap still connected, & MAP hose silicon upgrade; still random codes - no codes - engine light - or no engine light. The Light has been more constant lately & the codes P1171 &/or P1174. Sometimes they alternate, or team up, or disappear. Attempting to keep records of mileage & occurrence. Mainly happening at start-ups & fill ups. Is a wicked gremlin! :barf: :banghead: :banghead:
Was on vacation for a while, thanks for the replies. I will check out my options. Anyone know what psi the fuel pump should put out?
Hi, so a while back, I needed help and your suggestion about changing vacuum tubing to the throttle body was correct, thanks.
