The BajaRon Ultra SwayBar made a marked difference in the twisties, though I’m still not used to the pressurized Gforce lean characteristic of the Spyder. I’m sure it is from coming off of 55 years of active two-wheeled riding, and how carving the twisties on two-wheels seems far less labor intensive.
I wonder if a set of adjustable shocks would help, or am I to simply accept the G-forces at work here? ( I know, I know, slow down)
As far as the bike is concerned, I had no issues at all. Very impressed!
Two-wheel bikes have a heap of gyroscopic forces making the 'lean to turn' thing pretty intuitive - most 5 year olds can get that sorted pretty well with a little practice, but it does take years of practice to really explore the limitations. However, just because we 'graduated' from them to 2-wheelers when we were only just getting used to them, few of us riding
THREE-wheel machines like our Spyders have yet developed that 'thumb-in-bum, mind-in-neutral' capability on our Spyders, especially if you want to go anything much faster than a brisk walk!! So if you do want to go faster than that brisk walk,
YOU need to start to learn and practice how to take advantage of the Laws of Physics just like you do in your 2-wheeled riding thru those years of learning/practicing, only you now need to do that in way that suits the different set-up & riding dynamics of yourr Reverse Trike; and
YOU need to lean cos the Spyder can't; so
YOU hafta learn how to compensate for the lack of assistance from the gyroscopic forces that those 2-wheel machines you've spent years riding give you and you take advantage of so easily because of all those years on 2-wheels!!  :lecturef_smilie:
Look back thru the early posts on this, when
everyone was learning about how to get the best from their Spyders; those who'd spent time on other machines where they had to do the leaning took to it a lot quicker; those with years of 2-wheel riding behind them were often at a disadvantage; and there's discussion/mentions of things like: 'it'll take you
AT LEAST 1000 miles to even
start to get a handle on riding your Spyder'; 'you need to walk (or ride slowly) before you can run (or start learning how to ride fast!)'; '
Lean in & kiss your inside wrist on the tight turns'; '
brace your outside foot and push your weight across onto the inside of the seat'; and '
always Pull on the inside handlebar, DON'T push on the outside bar, it unbalances everything'; and a whole lot more...
hyea:
So don't give up just when you start getting the hang of it; work at it - your Spyder will need far more 'upper-body english' than any 2-wheeler ever did, simply because
YOU need to compensate for the lack of all that gyroscopic force that makes 2-wheel riding intuitive for most;
AND you need to learn to overcome all those years of ingrained acceptance of the help that your 2-wheeled bike was giving you & now your Spyder isn't! Once you learn how to take advantage of the Spyder's unique tracking ability instead of relying on any 2-wheeler's gyroscopic tendencies, you'll find that your Spyder can actually out corner pretty much
ANY 2-wheeler or 4-wheeler on the road, simply because
YOU CAN STEER and turn a whole lot tighter than they can turn, and do it at a higher speed too!
On a Spydrr, you can hold your speed longer, driving deeper into the corner without anywhere near the concerns on cornering traction; then brake later, carrying more speed into the corner; turning faster & harder at the appropriate point to apex/late apex; getting on the gas sooner on the way out; and basically carrying more speed into, thru, and then digging your way out of the corner a helluva lot sooner/quicker/faster than any 2-wheeler that's far more constrained by the gyroscopic effect, its need to lean to turn, its wheel-base, it's concerns re the traction reducing contact patch changes the further it leans; and the basic laws of physics that give your Spyder such an advantage! But
YOU DO hafta unlearn (or at least over-come the tendency to apply/rely on
 ) all that learned experience & skill from 2-wheelers that no longer applies here and learn a whole 'nuther lot of things that will make your Spyder such a fun machine, even more so than it might be now, once you truly get the hang of it and start chasing 'that ideal ride'!!
hyea: :2thumbs:
So you don't really need adjustable shocks (  shocks, possibly adjustable, might not hurt tho...
); nor do you need to accept the G-forces as a restriction; or even slow down! You just need to start working
WITH the Laws of Physics & working out how
YOU need to move & control your ride in order to take advantage of the significantly better traction, braking, and steering capabilities your Spyder has over any 2-wheeler!
Go On, DO IT!!  :yes:
