New Horn
Mikel53
I have a 2015 RTL and had the dealer put a loud after market horn on it when I bought it new. I washed the bugs off the other day and now the horn sounds funny. If I replace it what is the baddest, loudest horn I can buy to put back on it.
The Stebel would be my choice, with a relay. The Wolo comes in two versions, the 419 model is roughly the same as the Stebel, the 619 has a deeper tone at about the same volume.
john
Wash?
When you washed the Spyder, did you flood the horn with water. Try draining the horn and toot it again. It may work.
When you washed to Spyder, did you flood the horn with water. Try draining the horn and toot it again. It may work.
Agreed... If they mounted the air horn with the opening facing up, water will get in it and not drain out.
Bob
