oregoncoast
I put Wolo low tone horn on my Ryker, sounds like a loud horn from the old days. A 5 minute job, problem is that is requires a 10 amp fuse and the Ryker only has a 7.5 amp fuse. Putting a larger rated fuse could cause problems. I am hoping that the horn will not need as many amps as stated but will pick up some extra fuses just in case. Only time will tell if it will be an issue. The horn was around $11.00 on amazon and there are many to choose to choose from, probably any are better then the wimpy beep beep than is stock on the Ryker. I will get another for my Honda.
