Thanks.
Yes. I am following the instructions in the "manual", and it also says to take all air out of the airbag first. This automatically lowers the headlight position when you add air back in, and as you say, the headlight "reach" is then drastically shortened. With air back in, they show at the BOTTOM of my garage door ! Which, as they tell you to set from, is only 33' away. Doesn't seem right to me, how bout you?
Also, do you know what size allen wrench? I've tried a few of mine and none go into that fitting.
GOT IT !! it's a 3/16" Allen Wrench! Now waiting for a darker sky by my garage door !
Incidently…...I found some past posts on this procedure and some referred to doing the alignment with "passenger/passengers on board. Nowhere in the 2014 RTL manual does it mention that as part of the process, and I assumed (yes, bad on me) that this process was a benchmark measurement for any riding situation and would be OK for any riding combo. Also noted that some thought having "0" in the airbag would give you the "highest elevation" setting. (IMHO) I don't believe this is true. When you then add air to the bag, it raises the back and consequently LOWERS the light aim (and firms up the ride too), and you will have a very short sight distance again. Seems to me (now), that what you set them at is a very personal elevation based on your comfort after dark. So...……………………………...Guess I'll need to "play" with it after dark up and down the driveway.
