warp10
Just installed new fog lights on our RT a/c. Carefully read all the directions, and decided that was too much work, remove the entire front end. :yikes:
Looked the setup over and decided that I could reach all the bolts, small hands, and install all the bolts (4) that it takes and not have too remove the front end.
Took about 2 hours for the first side and about 30 min for the other side. Plugged in the connections, added the switch and turned on the key, nothing. :yikes:
Decided that the bike had to be running for the fog lights to work, started up, bingo we have lights. :yes:
BRP makes working on these way harder than they needed too. would have liked simpler screws to hold things on, instead of all the hidden plastic slots and push pins.
