BajaRon
Well-known member
It has been brought to my attention that EBC has completely changed their recommended 'Bed-In' process for new brake pads. They are no longer recommending the quick process of hard braking over several consecutive events when used in a street application.
My feeling is that the original recommended process was tailored for race vehicles which do not have a lot of time or miles in which to get the brakes up to 100% efficiency. After-all, the original application for Sintered pads was for racing. But more and more people are finding they work very well on street applications as well.
So, for whatever reason these changes were made. Here are the new recommendations from EBC for bedding-in their pad sets. I see it, basically, as drive and brake as you normally would, trying to be a bit easier on the brakes (if possible) until you get some stop & go miles on them.
Their process makes it sound like it takes forever for the pads to work effectively. I have not found this to be the case at all. This may apply more to cars than to our Spyders.
Bedding in EBC pads
In Street use situations …
Best procedure is to drive gently avoiding harsh braking unless in an emergency for first 100 miles. In the second 100 miles (up to 200) you can use gently increasing brake pressures when using the brakes.
Only after 200 miles urban driving (not 200 miles on a freeway where brakes are almost unused) should you attempt to apply heavy load and heat to the brakes. To do this final bedding on a QUIET ROAD in safe traffic apply the brakes and slow from 60 to 10 MPH five times in a row. Then drive slowly for a few minutes if safe to do so to allow the brakes to cool. Try to avoid coming to a rest whilst the brakes are heated.
A smell may be noticed from the warm brakes, this is normal. Repeat this procedure a second time after the brakes have TOTALLY cooled down. EBC pads get better with miles. Even after this bed in procedure it can take up to 1500 miles before the pads are at their best. In the meantime the pads will be good and safe but true potential not realized. EBC makes performance pads that last, they do not bed in within 5 minutes driving. Noises will be more likely during the first 1000-1500 miles use whilst this chemical bedding takes place.
NEVER attempt to sand or Scotch Brite brake pads to assist it bedding in or noise reduction. This will only make things worse by taking the pads “Off-Flat” and require hundreds of miles driving to seat them again, during which time the brakes will feel very dull. The only way to seat pads is against the rotor they will be used on, and by following our bedding recommendation.
Bedding in EBC pads
