JuanB75
I picked up a 2010 RT-622. It needs some work especially on the wiring. It has the 9 pin round connector on the trailer and my 2017 RTL has the 4 pin flat connector wire harness installed. I am seeing horror stories about converting the trailer to a 4 pin flat. Not sure how to do it. I'm not an electrician by any means. I have tested the wiring from the Spyder and everything is operating as designed. I have removed the 9 Pin round connector from the trailer wire harness and have labeled each wire per the wiring diagram. Of the 9 pins, only 7 have wires of which only 6 are active.
Here is the wiring arrangement:
1. Ground = Black
2. Running Lights = Brown
3. Right Brake = Red
4. Left Brake = Orange
5. Back-Up Lights (Not Used) = Yellow
6. Right Turn = Green
7. Left Turn = Blue
The 4 Pin connector I'm going to splice in to the trailer wiring is a standard one with : White to Ground, Brown to Running Lights, Yellow to Left Turn and Green to Right Turn. I hope someone knows how to or has a wiring diagram that I could use. If I need some other part for this please include the part number or where to purchase it.
Thanks
1. Ground = Black
7. Left Turn = Blue
Thanks
