Need to Release the Parking Brake ...manually - Anyone help?
nealperkins
I have a 2016 F3L with a significant electrical problem. I have an appointment with a dealer in a couple of weeks.
I understand that there is (?) a way to manually release the parking brake?? That would be a good thing as I have zero electrical power...and, it is not the battery.
Would you know how to do this?
Thanks
You go to the back and unhook the cable from the calliper; or release it from the spool on the actuator up front.
You go to the back and unhook the cable from the caliper; or release it from the spool on the actuator up front.
Thank you for responding! Would you know which would be easier for a novice?
Neal Perkins
Yep locks the rear.
Link works for me.
Top right of the page there is a search box.
I typed Parking Brake Release.
Yep locks the rear.
Link works for me.
Just for info, that link doesn’t work for me either, Iso……..it just takes you to a screen that effectively says - no matches.
Pete
and...does this parking brake lock just the back wheel?
Yes, just the back wheel…..and as Iso says, type Parking Brake Release in the search box. You can release it with a couple of spanners, but I can’t remember the size and I am heading out.
Pete
Not sure about an F3, but on my 2017 RTS, two 12mm wrenches will back off the nuts on the brake cable at the rear wheel. I had to do that when my parking brake failed in the locked position so I could get it towed to the dealer. Really easy to do. Good luck.
Have a surf through some of these. Should give you an idea.
https://www.spyderlovers.com/forums/search.php?searchid=3807937
Bummer, bad link.
Or, do I have to 'get inside' an archive section?
Sorry Neal, but that's cos Iso can't post a usable ink to HIS search results, the system won't let him - cos the results that Iso saw & posted a link to was in response to info that HE'd entered into his Search Selection screen, and you don't have any of that Search entry detail, so you get the "Sorry, no matches..." or the 'Invalid Link' messages displayed instead of his results!! :lecturef_smilie:
So Iso, it doesn't really help anyone if you post a link to YOUR Search Results page, cos no one else will be able to actually see that info :( - they just don't have the necessary selection detail entered!! :banghead:
They MIGHT be able to open & submit the Search Selection screen you used to submit & get that results page if you linked that instead, but that working seems to be a bit hit & miss, so as you also did, I find it's much better to simply tell people what keywords/criteria to search on... and then if they can't be bothered to actually DO the search themselves, it's on them... ;)
That's not saying that I think YOU wouldn't do the search Neal, just that we have some regular offenders here who don't ever bother.... and those, the people who don't ever make any effort to do anything for themselves but instead just want others to feed them all the answers on a plate, those we can't really help all that much.... :p
Just Sayin' :thumbup:
Himm. Ok.
Post #7 I typed...
I typed Parking Brake Release..,
Hope he sorted it despite my best intentions that lead nowhere by the sound of it.
....... but that working seems to be a bit hit & miss, so as you also did, I find it's much better to simply tell people what keywords/criteria to search on...
Himm. Ok.
Post #7 I typed...
Yeah, I noticed that, but I was just trying to clear up WHY your links weren't working & couldn't work no matter how many times you posted them...:(
It's not anything you did really, it's just that the system can't show others the same results you got when they don't have the same 'Search Selection' details entered - so they'll hafta go to the Search field or screen & type them in. :thumbup:
Well, I got down on my side to look at the area I need to work...Wow! There's about 7" to go under the muffler. Either that comes off, or I need a jack. So, the spring comes off easy enough. Then I'm staring at the bolt that apparently holds the bracket connecting the cable to the 'swing arm'. That also looks very doable. Someone commented that this would be their preferred way to solve this problem... remembering that the Spyder would be reassembled at the dealer. So, is this actually the easier way to get the brake released?
I thank everyone for their assistance!
Neal Perkins
Yup, and I think you have to release that to take it off at actuator. Not that bad, 12mm open end. Had to do it several times on my 18.
Neal Perkins
That is one of the two most common ways to do it, Neal. Undo that bolt now that you have the spring off, and take bolt, plate, and spring to dealer. I have a recollection that the bolt is 13mm for some reason… my memory is not what it was. ;)
Pete
Pete
Pete, thanks so much. That's what I am going to do. And, I've heard the 13mm before.
You guys rock!
Neal
If you need a little more room or wish to get a little higher off the floor, well I run it up onto a bit of timber, a 4"x4" with an angle cut for the leading edge. Makes a big difference for me as im not as agile as I used to be.
