Need instructions on removing 2020 RT left side inner panel
KenF
Does anyone have instructions on how to remove the left side inner panel on a 2020 RT Limited.:banghead: I know about how the top panel and outer panel come off. But have never seen any one mention the inner panel. This panel needs to be removed to access the the belt tensioner pully.
All you need to remove is the black piece above the drivers' left footboard. There are 3 torx screws at the front about even with the rear of the front fender. Then there are the 6 screws around the rest of that panel. Be careful putting these 6 back in; they only go into plastic and are easy to strip. I've added the belt idler and changed out my front pulley to the white one through this panel only.
