ZDarkman
I started installing Seal floorboards (RT SM5 PUP DLX) back in December but had to stop because I kept getting a cold after laying on the garage floor after the cold weather arrived here in NJ.
At the time of the installation, I replaced the shifter arm with the new one that came with the kit and thought I kept the linkage exactly at the same length. At that time I did not turn or twist the linkage arm at all. Just unbolted the old arm and linkage and bolted on the new arm with re-attached the linkage.
After that I went to start it and check everything out, but could not get it into neutral only 3rd, 4th, and 5th. Since then I took the shifter and linkage off several times and made several adjustments but the best I could get is 2nd, 3rd, 4th and 5th. I do not have the correct tools at this time to make this job easier. So each time I need to make an adjustment to the linkage bar, I must remove the shifter arm. I do not have the proper tools to leave the shifter arm on and just remove the linkage. I do not have an offset 10 mm wrench to just take off the linkage arm from the shifter.
My question is, is there a trick to re-adjusting the linkage arm such as putting the bike in 2nd gear and then try adjust the linkage arm from more of a mid way point. I thought this would be a 1 2 3 process, but WOW, was I wrong.
Any help would be deeply appreciated.
