Need help removing hitch to change rear tire / Please
MikeP
I removed the caliper and the long bolt that goes thru the axle ,, so what am I missing?? I assume the hitch should come right of with a tug to the rear... Any help is welcome:)
the hitch fits tight to the swing arm.I USE A SOFT DEADBLOW HAMMER TO tap thehitch back and forth to work it off be careful not to damage the sensor wire when removeing hitch.No need to remove caliper to remove hitch
Thx,, I removed the caliper to change the tire / have to get the hitch off tooo..
Where is the sensor wire???
I apologize. I didn't read your question accurately. The video, although perhaps helpful, really doesn't answer your question.
​Chris
