Need Advise on Installing Air Horn
EzeSpyderGA
I am looking to install a Rolo "Bad Boy" air horn and wanted to know if the Spyder RTS original horn circut can handle the current draw from the air horn or would I need to install a relay in the circuit to buffer the current draw?
From what I have read around here, you will need to use the relay. Hopefully someone more knowledgeable will post up the whole electrical reason. There is a write up in the how-to that shows how other have done this. This reminds me that I still need to install the wife's.
Sent from my DROID X2 using Tapatalk
Fitting Air Horn
You might want to look at the earlier Thread
http://www.spyderlovers.com/forums/showthread.php?32217-Mounting-a-Stebel-Nautilus-Air-Horn-on-the-RT&highlight=horn
Or just put Stebel in the Search Box
Hope this Helps
Eddie Sheppard
Reading UK
Thanks for the information
Thanks for the input and yes I am going to use a relay as suggested. The link you listed was fantastic. Thanks again for responding.:clap:
