Over view 2012 RT limited, new 100 days from purchase problem, first issue no horn working, and showing manual mode in suspension system, I found common link of the 20 amp fuse in frank blown a quick fix not, replaced horn worked, when I started to drive the bike no horn and manual display again. Also noticed prior to problem the air ride system would bleed air we could hear at stop lights and in garage. Linkage is conformed connected. Took to dealer they returned it a few days later said all was good found no problem. Today I was adjusting ride by switch heard no air bleeding went through it full hard then soft, with engine running, in gear, brake off I was in garage and set reference line on wall with lights ran it full hard and soft heard nothing and saw no movement in light marks. The led display shows bars moving hard to soft and horn works. I think you should feel some movement while adjusting the air ride while on the bike. Will the display show it working even if the compressor is not working. Maybe this is why they said it was fixed and not blowing a fuse again. Please advise my spider friends
