N00be needs someone in SC to ride my spyder
pondboss
I need someone fairly close to me, (Florence, SC) to ride my 2013 RT LTD. Been riding motorcycles since age 14, Honda trike for 7 years and can't keep the Spyder in a straight line on the interstate. It's like I'm riding a snake !! Loose grip on handlebars and confidence~ but my confidence is fading.......Dealer says it's all me and it may be but I want someone experienced with a 2013 RT to tell me (it's me) or not. I'll come to you and buy you a coffee for taking a test drive.. Anyone up for the challenge ??
First off, you may be gripping the handlebars to tightly. Loosen up. Second, you may want to upgrade the swaybar with a BajaRon's. Great add-on, and should help you out a lot. Let me know if this helps. P.S. Check the tire pressure in the fronts. Make sure they are both the same PSI. And you may want to stiffen up the shocks, just a thought. Hope you soon have many happy miles w/ lots o' smiles:yes:
I think its time u asked for a second opinion from a new dealer as to weather the ball joints have been changed and the alignment is within specks if all is good from there than someone else may have some answere to your riding behaviors and what u can do to help.
pondboss,
When I first got my Spyder (I have two now), I struggled to keep it in my lane. I was certain there was a problem with the steering that was causing it. I'd been riding Goldwings for over 20 years. I actually pulled over to the side of the road and began thinking about what the possible causes could be. It then hit me...
When my brain says "turn right", my arms take the necessary actions to turn right. I don't have to think about how to do it, it just happens due to muscle memory. The arms already know how to do it. That turned out to be where I failed. My motorcycle experiences were on two wheels. Because a two wheeler leans to make the right turn, the driver has to actually nudge the handlebars slightly left to initiate that right hand lean, thereby making a right hand turn. The technique is called counter-steering.
The Spyder, on the other hand, does not lean. So when my brain said "right turn" & my arms did what they normally always do by nudging the handlebars to the left, the Spyder went in the opposite direct than was expected. That combined with the unexpected inertia tossing me to the outside of the turn, really got my attention and raised all kinds of red flags. I then figured it out: I have to actually turn in the same direction I am wanting to go, which is opposite of what I've always done on a two wheeler. I also have to force myself to lean my body into the turn, when necessary.
Not only that, I had to adjust the timing of my turns. Going back to a two wheeler, when you want to turn right, you initiate the turn slightly before you actually want to start the right turn. There is a slight delay because you're using counter-steering. The first nudge initiates the lean, then the turn begins. It's subtle, but the timing is different. I found that on the Spyder, I was entering my turns a touch too soon. The reason being that as soon as I initiated the turn, the Spyder started to turn.
This same problem is evident while going on straight roads, as you are constantly making small corrections to go straight.
Once I thought through the steering and timing differences, I was able to re-train my arms. Now there's not much thought given to it anymore. I still have the Goldwing & have found I can switch back & forth without any difficulty.
I think, if you think about how to steer again, something you've probably not given much thought to in a long time, you'll understand what I'm telling you.
I :agree: with the above. While all of the add ons like the sway bar and shocks make the ride better you should be able to ride the Spyder just fine on the highway. First make sure that you have around 18-19 psi in the front tires and 26-28 in the rear. Then take it out on a stretch of road, hold the bars lightly and if all is well it should go straight. If not back to the dealer! Put on your game face and don't take no for an answer! Just had a thought it could be bad tires also.
new bike
Maybe try another dealer if you don't get any satisfaction. Velocity Powersports in Ladson, SC has great service. Good people to deal with.
Another idea
Another factor to consider is the crown of the road your having the problem with. Our roads in FL are a mess some old,new,half wore out making steering for a machine as agile and quick as your Spyder. Go find a newly paved road and try it if that does not tell you something then go to a plan b.
Be sure an post your progress here as you check each step off as you go down your check list. That one thing will help the professionals out a lot so us dummies can learn too!:yes:
