My Pedalbox Pro arrived; is installed & set up - just need riding weather to try it out!,
AmigoJack
My pedalbox pro arrived, plug and play easy to install, set it up via the phone app, super easy, now I impatiently await spring riding weather to give it a try.
How or how to I turn a photo into a thumbnail, I cannot figure it out.
If you photo is small enough it will appear in a box after you select it from "attach files" then you will see "inset" when you select that you can choose "thumbnail" as an option. If the box does not show you the photo then it is too big, you will have to reduce the size to around 250 -500 KB.
