My results after having the modifications recommended by BRP to address the "Heat Issues" being experienced in the CanAm 2013 RT.
The results I have found pre and post "BRP's 2013 RT Heat Fix" on my 2013 RT Limited Edition SE5.
Firstly an item that may be of interest to some owners is that I was credited (dealership credit) with the full cost of the OEM Adjustable Air Deflectors I had previously purchased and fitted to my RT.
A little history on my 2013 RT Limited Edition SE5.
It has had the left hand header pipe wrapped where it runs alongside the fuel tank and still has the catalytic converter fitted. The under body panel that several owners have reported removing is still fitted although I have drilled several (lots actually) 25mm (1 inch) holes in the hope that it may have allowed better air circulation without allowing road debris to damage fittings located in that under body area.
I haven't experienced any fuel odours since last having the purge valve and charcoal canister replaced.
The Work :- My RT was the first to have these works carried out at my preferred dealership (Springwood Suzuki - QLD, Australia).
Work commenced at 8:30am and was completed at just prior to 5:30pm.
While I was having "the fix" carried out and my RT was very naked I took the opportunity to have the spark plugs and leads swapped out with high quality NGK Iridium spark plugs and Accel Race Wire leads (supplied by Martin at
www.spyderryders.net.au) plus the 15,000klm service was completed.
The Temperature :- How accurate the temperature gauge I used I don't know but as all readings were taken with the same gauge I believe the difference between pre and post "the fix" do give a very fair indication of the effectiveness of the modifications that BRP has recommended to be carried out.
Readings were taken in 12 different locations around the exterior of the tupperware, in the glove box and under the seat.
The first set of readings were taken where the ambient temperature was approximately 10°C (50°F). All readings were pretty much that of the ambient temperature.
I then undertook a 100klms (62 mile) ride and on reaching my destination took another set readings at those same 12 locations. These readings I will later refer to as pre "the fix" temperatures A further set of readings were taken after an 80klms (50 miles) ride after having "the fix" completed. I'll refer to these as "post the fix" results.
Also of note is that the post "the fix" readings were taken when the ambient temperature was double that of the pre "the fix" it being approximately 20°C (68°F).
After "the fix" the majority of the external readings were all similar to the ambient temperature. I experienced no difference from the reported hot foot area pre and post "the fix", it was quite warm.
The areas where I found major temperature changes pre and post "the fix" are shown below.
1. Glove Box
Pre Fix - 46.0°C (114.8°F)
Post Fix - 20.8°C ( 69.4°F)
2. Seat Latch
Pre Fix - 62.8°C (145°F)
Post Fix - 34.1°C (93.4°F)
3. Fuel Cap
Pre Fix - 53.8°C (128.4°F)
Post Fix - 28.6°C ( 83.5°F)
Unfortunately I failed to take the temperature reading inside the fuel tank prior to "the fix" being carried out although I can state pre "the fix" I had experienced fuel bubbling (boiling) inside the tank on several occasions.
The following fuel tank readings were taken post "the fix" before and after an 148 klms (92 mile) ride.
Pre Ride
External - 17.0°C (64.6°F)
Internal - 18.8°C (65.8°F)
Post Ride - 148klms (92 miles)
External – 17.8°C (64°F)
Internal - 34.8°C (94.6°F)
As can be seen from these readings there is certainly no longer any bubbling (boiling) being experienced in my fuel tank.
Take all this information as you you wish but I for one am now a very happy CanAm RT 2013 Limited Edition SE5 owner.
Note:- Forgive me if my temperature conversion aren't correct but I believe I have them reasonably close.
A single proviso still remains, that being how the summer heat will affect my RT ?
Summer still being several months away here in Queensland Australia, so I'm just going to enjoy getting out and riding my Spyder every opportunity I get.
As a sidebar :- Winter here is real tough though, temps rarely getting below 8°C (46°F) overnight and days usually in the low to mid 20°C (68°F). My sympathy's go out to those snow bound Spyder riders.
Come visit here sometime it's pretty much perfect riding weather all year round.
I hope this information gives hope to all the owners that are still to have this modification done to their 2013 RT.
Regards
Kenn
