arkyleo
Finally installed my new Altimax (215/60/15) today after 5600 miles on the OEM Kenda. Tips from this forum were very helpful and much appreciated. Also hooked up the top exhaust spring to my Rick's cat delete pipe--much easier with the wheel off and on the H/F lift which worked great.
Test rode it and nothing fell off and the belt seems to be in the same alignment, and speedo is right on now according to gps. I used a method for tightening the rear axle nut that I have often used on other bikes and it seems to have worked and maintained the alignment. I tightened in 25'# increments and tapped each side axle nut forward with a 1" soft brass rod after leaving the adjusters in their original position by removing the lower shock bolt to peel the belt off. I will be running 18 psi front and rear solo.
