BLUEKNIGHT911
Sadly Passed Oct 2024 - RIP
Well the weather has been slightly mild in Vt...... so I got some more work done ..... attached the gas shocks that lift the Gull Wing doors .... decided they aren't as strong as I would like and one pair needs to shorter, so I ordered some different ones .... will get them tomorrow ....... Finished building the LIFTING cradle and attached the two pulley's and the ( boat ) winch along with the wire rope to do the lifting .......figured out how to detach the body from the frame ( almost forgot the steering column under the dash :yikes
( that would have been Bad ) ...Progress is slow due to the weather ... I had Frost-bite years ago and still suffer from the long-term effects ......WARNING AVOID getting frost-bite , cold weather will be more miserable, because of the previous damage:thumbup:............Later ...Mike
