My $35 version of "magic mirrors"
Williebbaker
After I had been taking my mirrors on and off several times over the years for various MODS on my 2010 RT.
My clips broke here on the retainer portion of the top Clip. See the piece from the broken clip?
One day as I was passing by my RT, I bumped into my mirror and the darn thing nearly fell off. I was furious at first, but then I remembered reading about using magnets to hold the mirrors on (magic mirrors). I thought I might give it a try. So here is what I came up with;
The parts I used were:
6 each -Magnets from “eBay” - Round Countersunk Ring Magnets 25 x 10mm Hole 6mm Rare Earth Neodymium
6 each Steel Washers
12 each Countersunk wood screws
1 ¼ inch long metric screws
First of all instead of the washers being cut down to fit inside the clip socket, I made it so the washers would fit over the clip while it is still in the socket while using the same screw holes but longer screws. You will have to remove the clip so you can pick up the holes. See pictures below.
Once the holes are picked up they should be counter sunk (the screws must not protrude above the surface of the washer).
Now proceed to do the rest of the washers. Here’s how mine looked when I finished.
Now let’s prepare the clips, first I had to modify the good top clip to match the broken one.
To be continued on my next post. See you next time ;)
My version of "magic mirrors"
Next trim the tab on the bottom two clips and then use afile so that the washer will sit flush and remove the metal retaining clips.
Now let’s install the plastic clip and the metal washer,note the slight “apparent” misalignment (it is necessary) for the center holeis the focal point not the outside perimeter.
Next let’s preparethe bike side, first the magnet, screw and washer assembly is shown below:
More on the next post only because I don't know how to do it all at once. Sooooo see you next time! ;)[SUB][SUP]
[/SUP][/SUB]
My Version of "Magic mirrors" part three
Remove the existing stud pin screws and replace them withthe magnet screw and washer assembly see picture:
pic 13.jpg[SUB][SUP]
[/SUP][/SUB]
By loosening the screw that holding the Tupper ware as shownbelow, this will allow for the Tupper ware slight movement to accommodate thespacer washer for the magnet:
After all the magnet assemblies are installed reattach themirror assemblies.
Aline the screw heads in the hole of the washers with aslight push and BAM! You have your very own set of “SNAPP MIRRORS”
I hope this helps someone outthere save some money and time !
Thanks for your time!;)
My version of magic mirrors part 1
Sorry for the confusion but I will add it now.
One day as I was passing by my RT, I bumped into my mirror and the darn thing nearly fell off. I was furious at first, but then I remembered reading about using magnets to hold the mirrors on. I thought I might give it a try. So here is what I came up with;
6 each -Magnets – from “eBay” - Round Countersunk Ring Magnets 25 x 10mm Hole 6mm Rare Earth Neodymium-( 350916709551 )
pic 4.jpgNow proceed to do the rest of the washers. Here’s how mine looked when I finished.
Next trim the tab on the bottom two clips and then use a file so that the washer will sit flush:
Whichever way you look at it or whatever order you might get it in, it looks like you've made a pretty good start on your own version of these Willie, Good Stuff! Well Done! :thumbup:
I thank you for all the work you put into this. I have a question. in the parts list you said 6 steel washers, but it there one for each plastic "clip" and 2 on each magnet?? so, shouldn't that be 18 washers, or am I missing something?
Ray
Ray
Good point! I was wondering that too. They look like brass washers. How about the sizes on the washers too please?
answer to the washer question
Thank you for your interest in my post. Now to answer the washer question. you will only need 6 washers ( 3 for each side ). the part number for the (steel) washers is 03830 and I got them from LOWES. You have to make sure that they are made of magnetic material.
the two washers that are on the magnets are PN " AN416 " washers and they are smaller and are only used for spacing.
Thanks for giving the part numbers, but i am a bit confused on there only being 6 washers....
You put the washers on the mirror side, and in the post i quoted, you are saying put the washers under the magnets. I was hoping to do this this weekend, so any clarification would be much appreciated.
Ray
I have had them on for a year. They work great. The only thing I suggest is keeping the top clip on the mirror. This hook is only used to "hang" the mirror off, and doesn't take any force putting the mirror on and off.
Last year when I first used this system, I was on a long trip, and hit a pot hole, and the mirror came off. Now, I had a tether, so it just dropped, but it actually did it a couple times on the trip. I put the top clip back on the mirror, and have not had another issue.
Ray
