Stephenaspr
Multiple Error Codes - VSS & DPS, P0600, U0126, U1101, U1150, & U1160 - any ideas?
On a recent trip, my 2011 RSS SE5 stalled at an intersection and brought up the following on the dash, VSS Fault and Check DPS, & VSS fault dash pilot light and when trying to restart it the idling was very erratic - between 2,100 and 6,500rpm. The Spyder could not be moved (unable to engage transmission) so was pushed a few hundred yards to the nearest premises where it was left overnight.
The next morning, it started normally and was ridden into town, once again stalling with the same messages / light when I slowed down, a half hour later when it was able to be started normally with a normal 1,400rpm, I headed off again only to have it stall when I slowed down for road works.
Two hours later it started normally again, and I was able to get it to the motel where it stalled in the car park.
The Spyder was transported on a truck to the nearest dealer 320 miles away, and after 5 weeks, I was told it was repaired.
I flew down from my hometown (935 miles away) to retrieve it and then proceeded back towards home, only to get 100 miles before it stalled yet again with the same error messages / VSS fault dash light.
One and a half hours later when it had cooled down, I was able to start it with a normal idle speed and ride it back into a town, where it again stalled on slowing down and with further error messages, ABS Fault, VSS Fault & EBD Fault, and upon restarting it, an erratic idling speed.
It was again transported back to the same dealer who yesterday advised that the following error codes were retrieved by BUDS - P0600, U0126, U1101, U1150 & U1160, only they were unable to find any fault, but further checking was to be undertaken.
All of the U codes seem to refer to damaged wires or pins in relation to the VCM and the P code a fuse (checked & good) or damaged wires or ECM pin fault.
Has anyone else had the above error codes/messages appear and what was the fault?
This dealer at 935 miles away from home is the nearest dealer to me, I would appreciate some idea of the problem so that I do not have to keep flying/bussing it to them and return.
