Moving the Spyder in the garage
5Wheels
I park the Spyder under my 4 post lift; I had to use the lift this morning but rather than walk back to the house to get the Spyder's key I jacked up the back wheel, put it on a small furniture dolly and pushed it to the nest bay. Only took a few minutes.
sledding!
The easiest way I have found to move my Spyder in the garage is to put two plastic roll up snow sleds down where the back wheel will sit. All it takes is a little push to slide back and forth up to about two feet in either direction! Works even better if you spray a little silicone between the two two sleds first.IMG_3109.jpgIMG_3108.jpg
